KLIMA VERSUS VYKON NA 1,4 16V 59kW
Vladimír Grnáč
PostPosted: Sun Jun 20, 2010 12:20 pm    Post subject: KLIMA VERSUS VYKON NA 1,4 16V 59kW Reply with quote
ZDRAVIM.MAM FUSION 7500km ,1,4 59kW .TERAZ KED SOM ZACAL POUZIVAT KLIMU, ZDA SA MI , ZE PRI ZAPNUTEJ MAM VELKU STRATU NA VYKONE.AKO KEBY PRIBRZDIL.JE TO NORMALNE?MOZE TO MAT SUVISLOST S TYM,ZE MI OBCAS PRI STUDEN.STARTE PADNU OTACKY NA MINIMUM,PRIPADNE ZHASNE MOTOR.IST S TYM DO SERVISU KYM JE ZARUKA?VDAKA
PostPosted: Sun Jun 20, 2010 12:37 pm    Post subject: Reply with quote
S těmi otáčkami to asi v pořádku nebude,ale že to netáhne jak bez klimy je normální... ale tohle už se tu rozebíralo Wink
PostPosted: Sun Jun 20, 2010 6:24 pm    Post subject: Reply with quote
http://fusion.fordclubs.org/forum/viewtopic.php?t=50
skopiroval som tvoj prispevok tam
LOCK Exclamation
