Posted: Wed Apr 25, 2007 8:53 am Post subject: ADITIVA |
TI ČO MAJU DIESEL,POPROSIM O VYJADRENIE,DAVATE ADITIVA CELY ROK ČI LEN NA ZIMU,A JE NEJAKY ŠPECIALNY PRODUKT PRE STREKOVANIE COMON-RAIL,NIEČO SOM O TO ČITAL,DIK ZA INFO. _________________ FORD FUSION 1,4TDCI,2004,COMFORT FRESH. |
ivoivo
Posted: Wed Apr 25, 2007 9:17 am Post subject: Re: ADITIVA |
DANID wrote: | TI ČO MAJU DIESEL,POPROSIM O VYJADRENIE,DAVATE ADITIVA CELY ROK ČI LEN NA ZIMU,A JE NEJAKY ŠPECIALNY PRODUKT PRE STREKOVANIE COMON-RAIL,NIEČO SOM O TO ČITAL,DIK ZA INFO. |
jatiež pridavam aditivum ma to znacku castrol tda dava sa 1/1000 takže po tankovani zakaždym cvrknem do nadrže či to ma vplyv ťažko povedať.
mam najazdene len 6000 km _________________ 1,4 tdci Strieborna Mondust 12/2006 |
Posted: Wed Apr 25, 2007 9:19 am Post subject: |
nie, davam len ked sa riadne schladi. +Aditivum vozim v lete so sebou pre pripad ze by som potreboval natankovat niekde panu bohu za chrbtom. Tam by som to pre istotu hadam vylial aj cele Cital som o ludoch co tam zakazdym naleju pol litra aditiva. To uz je IMHO sialenstvo. _________________ Ford Fusion 1.4 TDCi 7/2006
Posted: Wed Apr 25, 2007 12:54 pm Post subject: Re: ADITIVA |
mam najazdene len 6000 km[/quote]
CASTROL JE DOBRY ALE ČITAL SOM ŠPECIALNE PRE COMON RAIL,KUKNI NA :PRhttp://www.liquimoly.sk/pages/oprodukte.php?ida=113E _________________ FORD FUSION 1,4TDCI,2004,COMFORT FRESH. |
Posted: Wed Apr 25, 2007 12:56 pm Post subject: Re: ADITIVA |
VPLYV TO MA ISTO,ČISTI TRISKY,ZVIŠUJE CETANOVE ČISLO A NAFTA JE MASTNEJŠIA,LEPŠIE HORI. _________________ FORD FUSION 1,4TDCI,2004,COMFORT FRESH. |
Posted: Thu Apr 26, 2007 8:53 pm Post subject: |
DNES SOM ZHANAL PO OKRESE ADITIVA A NIČ NIKDE,ANI PUMPY ANI PREDAJNE MUSIM LEN CEZ NET,BUL SHIT FUCKIN _________________ FORD FUSION 1,4TDCI,2004,COMFORT FRESH. |
Black storm
Posted: Thu Apr 26, 2007 9:01 pm Post subject: |
Ja nepridavam nic akurat netankujem naftu mimo shell aral a omv. Myslite ze to je treba?
A co raz za cas dat 3-4 nadrze power dieselu? Ma to asi rovnaky ucinok ako tam nieco furt liat. Ci nie? _________________ Ford Fusion 1,4 TDCi 12/2004,
Posted: Thu Apr 26, 2007 9:17 pm Post subject: |
Black storm wrote: | Ja nepridavam nic akurat netankujem naftu mimo shell aral a omv. Myslite ze to je treba?
A co raz za cas dat 3-4 nadrze power dieselu? Ma to asi rovnaky ucinok ako tam nieco furt liat. Ci nie? |
NO ANO ALE JE ROZDIEL "VERIT PUMPAM" A TYM ČO TAM SAM PRIDAM"ADITIVA"TAK SA RADŠEJ SPOLIEHAM NA SEBA _________________ FORD FUSION 1,4TDCI,2004,COMFORT FRESH. |
Posted: Fri Apr 27, 2007 6:39 am Post subject: |
no v zime treba urcite kdekolvek. Nazrazany parafin v nadrzi moze narobit galibu. V lete IMHO netreba vobec a vazne len na to ked je clovek donuteny natankovat na nejakom jurky alebo podobne. _________________ Ford Fusion 1.4 TDCi 7/2006
KK
Posted: Sun Apr 29, 2007 10:08 pm Post subject: |
Dávám aditiva celoročně, kupuji Castrol. Dávkuji cca předepsané množství. Comon rail je hodně choulostivý na shit naftu a tak jistota je jistota i když zajedu k mnoha lidmi vychvalovanému Schellu. Dával jsem je roky i do Escorta. Tem má dle dokumentace životnost vstřiků cca 120 000 km a oni mají 200 000 km a jsou stále OK. O čerpadle mi říkali že jde do kelu a asi 7 let mi to při každé návštěvě servisu zopakovali. Aditiva aditiva aditiva a věřte že i ten všemi proklínanej motor šlapal - i v mrazu nastartoval (rekord byl -18 C na 7 pokus ) bez jakýchkoliv pomůcek.
Když to shrnu, tak těch cca 260 Kč za aditiva do 600 l nafty která stojí cca 18 000 Kč je těžce zanedbatelný pakatel a když vezmu, že to může zachránit třeba i 100 000 Kč za komplet opravu a výměnu pomalu poloviny motoru, tak kroutím hlavou nad těmi kteří nedají.
Občas koupím i jiné ( malá červená lahvička a je to na 100 l ) bohužel nevim jak se jmenují ( u pump jsou hrozně málo a já je koupím po paměti vzhledu a vždy aspon 5ks ), pak ještě od VIF. Jiné nekupuji. Obojí aditiva mají trochu blbou láhev na dávkování, ale když si to přelijete do lahve od Castrolu, tak paráda. Má hodně špičatý hrdlo a pěkně se zní dávkuje přímo do nádrže. Tomu kousku plastu je úplně jedno co do něj nalijete. _________________ KK
KK
PS - nalil jsem aditiva do nafty hned při prvním tankování i přesto že v návodu to zakazují. _________________ KK
Posted: Tue May 01, 2007 1:06 pm Post subject: |
KK wrote: | PS - nalil jsem aditiva do nafty hned při prvním tankování i přesto že v návodu to zakazují. |
MYSLIM ŽE TO ČO ROBIŠ MA LOGIKU,BUDEM SA TIEŽ TOHO DRŽAT! _________________ FORD FUSION 1,4TDCI,2004,COMFORT FRESH. |
Posted: Tue May 01, 2007 1:54 pm Post subject: |
mne tiez vo forde hovorili ze netankovat bezsirnu naftu ale normalnu a nepridavat ziadne aditiva, az potom som zistil ze net je plny ludi co sa tym riadili a teraz maju len oci pre plac. Ja som zacal mixom a teraz skusam 5-6 nadrzi za sebou co to spravi. Slovnaft pise vyslovene:
EVO Diesel je špičková pohonná hmota bez obsahu síry, vyrábaná na základe najnovších inovačných výsledkov skupiny MOL.
Pohonná hmota EVO Diesel predstavuje kvalitatívnu špičku ponúkanú na čerpacích staniciach. Jej používanie Vám garantuje maximálnu ochranu palivového systému motora pred koróziou a tvorbou usadenín, znižuje dymenie motora. Jej komponenty tiež chránia motor pred nadmerným opotrebením, čím sa zvyšuje jeho prevádzková spoľahlivosť a životnosť. Používaním pohonnej hmoty EVO Diesel sa zvyšuje efektivita prevádzkovania vozidla ako v lete tak aj v zime.
Použitie pohonnej hmoty EVO Diesel v lete zaručuje motorovým vozidlám s dieselovými motormi kvalitu a výkon naviac. Výborné zápalné vlastnosti zabezpečujú lepšiu akceleráciu a jedinečný zážitok z jazdy. EVO Diesel ponúka zvýšené cetánové číslo oproti normou stanovenej hodnote min. 51. Cetánové číslo u motorovej nafty je obdobou oktánového čísla u automobilového benzínu. Vyjadruje energetický potenciál, ktorý je v palive obsiahnutý. Zvýšené cetánové číslo znamená pre užívateľa mnohé výhody (zlepšuje sa vznietivosť paliva, optimalizuje sa priebeh spaľovania, čím sa zvyšuje výkon motora a efektivita využitia paliva) a znižuje spotrebu.
V zimnom období predstavuje EVO Diesel ideálnu voľbu vďaka svojim nízkoteplotným vlastnostiam, ktoré zabezpečujú bezproblémové štartovanie a prevádzku aj pri teplotách -30°C.
EVO Diesel vďaka najmodernejším syntetickým prísadám chráni a čistí motor a obmedzuje jeho dymenie. Pri použití tejto pohonnej hmoty je chod motora tichší. V záujme ochrany životného prostredia je pohonná hmota EVO Diesel vyrábaná bez obsahu síry, najmodernejšou európskou technológiou. EVO Diesel v tomto ohľade s výrazným predstihom spĺna kvalitatívne parametre motorovej nafty predpísané Európskou úniou od 1.1.2009
EVO Diesel je ideálna voľba pre všetky dieselové autá a spĺna požiadavky najmodernejších hnacích agregátov motorových vozidiel. Vyslovene sa odporúča pre moderné dieselové autá s motormi typov JTD, TDI, PD-TDI, HDI, Tddi, TDCi, i-CTDi a CDI.
...bezsirnu odporucaju aj do tdci, takze budem viac verit oficialnym vyjadreniam rafinerky ako nejakemu obchodnikovi z fordu. Ked uz rafinerka napise ze klasicka nafta je dobra do starsich typov dieslov a do nakladnych aut, tak by mal clovek spozorniet. _________________ Ford Fusion 1.4 TDCi 7/2006
Posted: Tue May 01, 2007 6:29 pm Post subject: |
NO NA SLOVNAFT BY SOM SA NESPOLIEHAL,VIEME VŠETCI HADAM O TOM AKO SA TAM ČI UŽ URČUJU CENY BENZINU,ALEBO NAFTY,ALEBO AKE KVALITNE PRODUKTY PONUKA. _________________ FORD FUSION 1,4TDCI,2004,COMFORT FRESH. |
Posted: Sat May 05, 2007 8:07 pm Post subject: ADITIVA |
KUPIL SOM CASTROL,UVIDIM,ZATIAL BEZ PROBLEMA,DOSTAL SOM DOPORUČENIE NA
WWW.METANOVA.SK,
MA NIEKTO SKUSENOSTI S TOUTO ZNAČKOU?DIK ZA INFO. _________________ FORD FUSION 1,4TDCI,2004,COMFORT FRESH. |
